Crush sleeve? For a Dana? If it don't turn, you got to many shims under the big bearing cup or not enough under the front bearing. Normally if the two pinions have the same diminsions (say 3.125) use the same spacer shims under the cup, preload can be different amount of shims. If you don't have the set up tools, it's a hit or miss situation.
