It takes a pretty good short to blow a fusible link. Good luck finding it.
My Taurus SHO would blow a fusible link every time I let out the clutch. As you can guess, I couldn't get it out of the driveway. After lots of looking I found the clutch cable end at the clutch lever on the transaxle had penetrated the main wiring bundle and wouldn't you know contacted the large red wire carrying most of the current.
R.
