Originally Posted By fourgearsavoy
Originally Posted By JohnRR
Is 21 a mopar flywheel ?
What do the front sides look like? If they have been cut at least once past the factory cut and/or are heat checked, and hard spotted, they might be scrap?
I had an old Ansen that was back-cut like that wheel with dual paterns shruggy
Gus beer
Reason I asked is because the bolt pattern is not the same as the others.
Dan B to the rescue.
running up my post count some more .
