UPDATE. After changing the complete fuel system from to the gas tank pulled, cleaned and sealed, new rubber everywhere, new fuel pump and filter and rebuilt carb, the car did the same thing. Changed the points/condenser and problem solved.
It didn't sound like a fuel issue to me. Hopefully you left the sock on the pickup tube.
