Originally Posted By elmor353
If you have a converter with weights on the front, you don't need to buy a B+M flexplate.
Maybe, depends on what it's weighted for. Not all external balance Mopar engines use the same imbalance weight. Assuming the weights you have are right is not a good idea.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
