Originally Posted By Charger453
Dove makes the rockers, I believe.
iagree scope
More than likely there is a axle and shaft, no needle bearings in the roller tip or on the shafts scope Those are extruded aluminum rockers with no caged needle bearing in the main body, correct? If so step up now and buy either a set of Harland Sharp roller rocker arm kit with 1.6 ratio or a set of the T&D single shaft 1.6 ratio rockers for your heads twocents up
