Try Comp's #23-472-8 (may have changed last number to 9). It is a solid roller with .575 gross lift. It has 262 duration @.050, ground on 110 lobe separation. It installs at a suggested 106 center line. We've run this cam in multiple motors, and every car was at least 3600# as raced.
In our 440 with modified 452 heads (2.14 x 1.81 valves) and at 13:1 compression, it went 11.17 @ 121.5 MPH. The MPH tells me that it had much more in it as for ET. It was run on M and H street slicks.
In the new 496" motor with Stealth heads. This combo has only been down the track on one visit, and ran an 11.62 @115 best. There were some issues that needed attention, and I know it will run mid-to-low 11's as is. It's very streetable, and works great with more compression. Good luck whatever you decide. Love '62 Dodges!!
