Hi Madscientist,
McLeod told me that the new 1200HP dual disc ceramic clutch will work just fine for my application for the street...they just told me not to dump the clutch at a standstill with sticky tires or I will break the transmission and rear end.
I am building a street hemi car that will not see a track, and will not be dropping the clutch at a launch...I just want great traction without any jumining around.
I thought the M&H Street Radials would be the ticket, and they also have the matching wide 8" tires for the front.
In my Street/Strip GTX I have a Lenco 5spd with a McLeod Soft-lok Sintered-iron Clutch that is designed for a clutchless transmission...So, I have a car for the strip,a nd one for the street.
Prior to the passing of Tim Hyatt (RIP) he told me that the Soft-loc will not work with a standard shifting manual transmission for street driving. McLeod told me the same.
Holley has a new Clutch out that is a long style, but noting to fit a Gen II hemi car.
So, what do you suggest?
Mark
Then McLeod and Tim Hyatt are both wrong. I drive a Sof-Lok on the street. Have for years.
If you are not going to beat on it, the M&H's will be fine. Didn't know you had a second car. Seen way too many guys say they will never hit the strip, buy a clutch like you did, and wonder why it won't shift above 6k or even less.
