Reproduction oil pan bolt set for big block Mopar worked perfect for me , including both the factory rear main seal retainer and Mancini Billet rear main seal Retainer when I screwed them in by hand , making sure they where not to long for each retainer and not bottoming out
Anyways
Plenty long for the two gaskets and factory windage tray plus the 402 oil pan
Mega Parts USA Oil Pan Bolt Set Big Block
Also Superformance Oil Pan Gaskets
http://www.megapartsusa.com/products.asp?cat=506
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
