Originally Posted By John_Kunkel
They all physically interchange but the yoke has three different u-joint profiles and the pre-'64 center thrust block might not work with '66 and later rear ends.
Open rear end only, the 64 and older thrust block is 1.25", 65 and newer thrust block is 1.5" so they will not interchange.
