It was actually ran today, so we know what it made, but will give you a chance to guess anyway.
This motor is going in my wife's 64 fury vert (if the body shop ever gets done with it). Will have a 727 and 8 3/4 with 3.23's behind it. Meant to be a nice cruiser.
413 block bored to 4.25", 3.75 stroke, 426 ci.
440 source heads worked over a bit by Brian (OU812/IMM).
Flow numbers
Lift Int Exh
.200 150 113
.300 220 145
.400 270 174
.500 292 195
Indy SR 1.5 rockers
Comp XE275HL Cam, .525/.525 lift, 231/237 @ .050, 110 ls, installed 4 degrees advanced
Ross flat tops, zero deck, 9.6:1 cr
Performer RPM manifold.
First, guess what it made with a holley 770 street avenger, vacuum secondaries
Then, what did a holley 950hp do for it?
So what do you think it made for hp and tq?
Rob, you don't get to play.
BTW, Mrs. G-bob's already asking if she can run the car down the strip.
