Has anyone had experience with installing a re manufactured, reprogrammed ECM and then immediately started getting new "check engine" codes that were not there before?
I got the unit pre-programmed from Napa to solve my "battery not charging issue", and the charging issue is resolved but now the codes appear but according to Napa it is not the problem. shruggy I don't really want to fight it.
Anyway, just curious if this is a common thing or not. The codes were not there before the change. The charging issue is fixed, btw.
eight
Mopar or no car
