I just did this swap,,,
I wanted to put on a different FAN,,,to keep the car cooler,,,
Got a fan from "Eric" here on the board ( he sells them,,and a few members run them )
The FAN is awesome,,,moves a TON of air,,,,
The issue of clearance came up with my old Moroso,,belt driven water pump set up....( which i didnt care for too much anyways ),,,belt from the WP motor ran off the front snout of the water pump
I got a Meizere pump,,,and swapped it in. Fit with no problem,,, MUCH more clearance,,,and the car runs way cooler,,,
I wired the fan and pump on seperate switch's,,,,last fall,,i had to shut the fan OFF,,,cause the car was running too "cool" ( which is a nice problem to have ),,,
There is a weight difference,,,,dont recall how much,,,,
Not sure i saw ANY change is HP going from the Moroso to the Meizere,,,but hard to say,,,,
Doug
Before ( with old Moroso )
After ( with new Meizere pump )
New Fan ( from Eric )
![](http://i212.photobucket.com/albums/cc79/69CHARGERMD/PA190010.jpg)
