I'm close to being done acquiring parts to put a 2013 mustang Shelby gt500 setup on my charger. 15" rotors with 6 piston brembo and 13.8"rears. My question to those with big brakes, what did you do with the master cylinders?
Did you switch to manual brakes or possibly hydroboost setups? Maybe one of you has insight on this. I'm leaning towards how hydroboost setup but I'm not sure if it will be the way to go.
Daaannnnnggg! How are you gonna find wheels and tires to fit the brakes with out giving up traction? There is limit to how well you can corner on skinny tires? I've told it takes 17" wheels to clear 13" rotor and 18" to clear a 14". So Will you need 19" wheels? Perhaps they sell bigger tires too, I'm not always the brightest bulb. One thing I do know is, that's one helluva set of stoppers you got there!
