when the time comes if you need more quiet You can add a pair of glasspacks in the tailpipes alongside the leaf spring. shop carefully as alot of em neck down significantly on the ends where the nipples are welded to the main case and the louvers are punched inward which hurts flow & going with 3" ones is an option
