Further up, OP said it was rebuilt with stock bushings. That typically means there is not a strut rod problem, but I'd certainly recommend looking into the whole strut rod and lower control arm relationship to the K-frame. If this combination of parts is not fully seated, the lower arm will be set too far back and cause the same inability to get caster.
