I bought the ones hughes sells for my big block. Don't buy them if you're going to run solid spacers/shims, they fit on the stud pretty sloppy and you have to reset them all up every time you take the rockers off. Ask me how I know, I should just run spacer springs and be done with it hammer
Now I need to pin those needles, got to feel that heat
Hear my motor screamin while I'm tearin up the street
