i am imagining you used a 4 cylinder dakota for the swap----budget fix--junkyard dakota v8 springs---i imagine original pickapart springs will run $70-----i would put those on and see where it sits----on my 50 hudson i used 2 inch drop spindles and cut one coil off the v8 springs and it sits at original height with a 750 lb motor....or if you are into just buying things and getting long distance advise then you are at the right spot....
