Re: What Can I Expect?
[Re: 77DragracerR/T]
#214190
02/06/09 10:38 AM
02/06/09 10:38 AM
Posts: 660 San Diego
formula S
San Diego
This winter the changes were going from a 360 to a 408.Everythng else is the same 360 combo.KB107 pistons +.009 out of hole .030 over,stock rods balanced,stock crank,974 heads ported with 2.02's or stock Eddys car ran the same Scott Brown 240/252H cam with 530/540 lift,Air Gap intake and 750hp carb and TTI headers.Ran 11.53 @ 116 with 1.52 60' 408 scat package KB744 pistons,forged rods & crank "0" deck,Crane cam 258/268 @ .050 560/580 lift 103 ATDC,Eddy heads but reworked,cleaned up around guides and pinch area,same intake/carb & headers. Running through a 999/904 trans low gear set with 4000 stall TCS converter with 4.30 gear and 29x9 Hoosiers. What ET/MPH will this give me? Thanks
Need more info,compression ratio, head flo#. Is the cam a roller or flat tappet
