...1954 was the first PF trans....
But, as said, if you do have the PF they are not complicated and if in working condition it saves you the cost of an adapter.
The down side for most folks is the parking brake assembly.
Now, if what you have is a Fluid-Drive or, a Hy-Drive......
www.qualityengineeredcomponents.com
Early Hemi Parts and Tech
EarlyHemi and flat 6&8 trans adapters
***inventory clearance in progress. Nothing held back. See website.***
