It is a stock eliminator trick to get a more direct flow into the combustion chamber. By doing so, you change the rocker arm geometry. You may need to open up the pushrod passages in the head, shim the rocker shaft, etc. I'm just going through this with my 318/4V Aspen. Picked up 4HP.
