Just swap the brakes from a later model A body on there. Lots of ways to go depending on if you want big bolt pattern wheels or 15 inch wheels so you can run the larger 11.75 rotors etc. You can put the small bolt pattern disc brakes on there too if you want to stay small bolt pattern.
