Originally Posted By Dragula
Originally Posted By Shatar4
The engine is a 505 stroker and the carb is a ProSystem 1000 cfm. The jets that are in it are 92 front and back. Way to rich.
Add idle timing, leave total timing where it is. It will take more fuel with more timing.
I am running 94's in my 1000 on my 512...Also, what idle bleeds are in it and HS bleeds are in it. You should have #70 idle bleeds, and #27-32 HS bleeds...I run the #27-#28's and it is dead on.
Idle bleeds are #76 and the HS bleeds are #32.
I'll add more idle timing and see what it does. Thanks for the suggestion!
