Originally Posted By ngpSatellite
hook up 12 volts and see if its moving... set time and check every hour for a day or 2 and You'll see if it accurate??
Is the clock also running on reduced voltage from the dash VR?...
I usually use a 6 volt DC lantern battery to check Mopar dash instruments for activation
