yup, speedometers on those trucks read off the rearend. Changing gears doesn't matter, I changed my 05 from 3.52 to 3.92 and speedometer was fine. Changing tire diameter is all that matters on those trucks. In the older truck where it reads off the transmission you have re-calibrate of you change anything down stream rear end or tires.
