Any reason I can't run my Dodge Ram CUMMINS 6 speed stick???
It's really slow, but so am I. ...
Hmmm, wind 3mph from west, diesel lines up in left lane, launches, makes lots of black smoke, car in rt lane waits for smoke to clear before seeing that the light is green and has been for 10 seconds, car launches cant see track, drives off into the wall
yep, sounds good
working on my car and trying to get it to launch. think I found a clutch problem. thought I was spinning the tires at Norwalk, was just spinning the flywheel. If all good, will see you there
