car went through a complete resto. Engine was apart when I bought it. Block was hot tanked and rebuilt to factory specs except for mild head work, 0.030" over, Cam is a Mopar Purple shaft 284/284, 0.484/0.484". Stock Holley carb (600cfm?)and stock intake. Distributor is factory that came with the car I disassembled/cleaned it up installed new points and condenser, cap and rotor. Coil is a OEM factory unit. Using new reproduction wires......
Original factory distributor with 1971 electric retard timing box along side vacuum advance diaphragm ???
If this is the case
