I use a Howe magnetic caster/camber gauge. You remove the grease cap from the spindle, then it sticks to the hub. If you have an aluminum hub, you remove the spindle nut, put a big steel washer on, then tighten the spindle nut back on. THe magnet then sticks to the washer. It is a bubble, and it is acurate and easy to use.
I called a bunch of local garages and asked if they had a set of turntables that weren't using. Scored a pair for dirt cheap. Ugly but they work.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
I don't regret the things I've done. I only regret the things I didn't do.
"Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
