As mentioned, body ground problem. Same thing happened on my 72 Satellite. The front lights were getting its ground through the instrument panel instead of the harness. One of the instrument panel turn signal lights was also dimly lit. The front harness ground can get corroded or break causing the problem.
iagree whistling
