Originally Posted By crabman173
Hi--will a 65 273 exhaust manifold seal and work on a std 340 / 360 head like a J head?? I know bolt pattern is same just wondered if it will cover the port and seal--Thanks!!
No, I had one customer do that exact same thing using OEM 1965 273 exhaust manifolds on a 340 motor with J heads in his 1965 cuda fastback, it was a real turd through those manifolds tskMeasure the height and width and go from there scope Maybe the Hi Po 4 barrel 273 mnifolds might, might scope have enough meat in them to allow opening(porting) them up big enough to work on the later heads shruggy
Let us know what you find out and do thumbs
