Originally Posted By 74RALLYE
440 with a little bit of cam - Nothing says "stay away from an Edelbrock carb" like a 440 with a bigger cam. Edelbrock carbs are excellent in most applications, but the 750 and 800 cfm models don't cut it on 440s with a little extra cam unless you like an off idle dead spot.
I couldn't get below a 13.11 w/ a eddy 750. I rebuilt and dropped a 25 y/o 750DP on it and the car went 12.90 and only would hit 13.0's if it was HOT out. I'd never run a Eddy on another BBM.
