I second the motion. That connector is the reason my Dodge has a replacement pickup coil in the distributor. It wasn't triggering the MSD so it had to be the pickup coil, everything else checked out. Later I found the corrosion in the female part of the chassis connector. Oh, well, it was only an hour and $15.00.
