Originally Posted By FastmOp
That's an easy weld
I agree... I'd burn that back on... I had a tail
shaft fall off my bench when I was building it and
cracked a chunk off... I burnt it back on and hit it
with a file.. no leaks... the only bad part.. you have
to pull the trans.... put some big Vs in it on
both sides and burn it in... I layed a straight
edge with clamps on it while burning
wave
