Quote: I don't know if these photos will help. This is from a 426 Hemi.
The red lines represent the oil flow through the cam journal.
are the hemis the same regarding this???? Also regarding the headgasket holes, I am using 318/340/360 type. I am fairly sure I looked at the holes when I put it together, But if no oil with an assistant, I may need to pop them again...
Officer to me... "I had my pedal to the floor and you were still pulling away like a rocket!"
