Originally Posted By justinp61
Is there a need or benefit for a mono leaf cal trac car to have any rake? I just changed the back halfs on my monos and my car is sitting pretty much level now. It has about 1/4" rake with the back being higher than the front.
If you have big torque the assend up a bit helps
but if your lower torque you would like that and the
engine sitting higher... makes for easier transfer..
and depends on the weight ratio front to rear
wave
