Starting with a non AC car, I would go all aftermarket. Finding and restoring a complete OE AC setup + changing the firewall would be time consuming and expensive. I understand the aftermarket units work well and are a lot lighter. Only downside is you give up fresh air. I doubt that would be a problem with a convertible.
