Will their rockers for their 360-1 & 360-2 heads fit a w5 head?
If so are they any good?
Also how long will the mopar/crane blue rockers hold up for a 230 lbs seat pressure and 630 open?
I have those pressures with my W-5 and the Mopar
blue roller tip rockers... they've been fine...
I believe you need the offset shafts and stands
but to be sure I'd have to look at mine
Do the shafts have banana grooves?
On my shafts the holes in the shaft fit the oiling hole in the rocker to the roller perfect but not for the pushrod so im thinking either a banana groove or drill an extra hole to the pushrod hole.
Or is oil spread out on the whole inside of the rocker so i dont need to do anything?
The Harland sharps doesnt even have roller oiling.
I measured rocker ratio today.
The Harland sharps where spot on at 1,5 even on the intakes (which should be a little more than 1,5 cause of the p-r angle). The blue mopars where actually close to 1,56.
The mopars have near perfect geometry so i think im gonna use the mopars.
