I think US Car Tool might also do similar work.
Pay attention to exactly what the install center does and does NOT do. They take off the old panel and install the new. They do NOT do any rust removal (other than the weld areas). So it that's something you want done, the smart thing to do is cut out some of the areas on the panels you want replaced and have the car or those ares blasted BEFORE you take it to them.
They do NOT do any collision repair so if the car was in an accident you should have it put on a frame machine before sending it out.
If you already have any AMD sheet metal they will install it at a slightly higher cost - understandable since they're not making any money off it.
I was impressed - just too damn far for me to take the car or they'd be doing it !!
