I did the speedo calibration today and got that done..
then on the way back I stopped and did a full on pass
and after I got that done the fuel system seem to shut
down.. this was well after I made the hard run.. it stayed
fired but I didnt understand the shut down.. also found
a MAJOR oil leak at the pass side valve cover.. the cover
is very close to the intake so I'm gonna double up that
gasket to see if thats the problem..I had issues there before
but I have to figure out the fuel issue... it ran REAL
STRONG on the run
Of course I had to make my pass on the drive way
to the ford proving grounds... LOL
EDIT
I forgot to turn off the OD and I was surprised
that the OD didnt even slip on the full all out
pass... I didnt think it would hold in OD without
reving up(slipping).. but I sure wouldnt want to
do that very often... I wish I would have opened
up the dumps
wave
