Originally Posted By DAYCLONA
Originally Posted By JohnRR
Pictures of this INSTALLED???
Kiesler was great for a NO CUTTING required install that made a mess of the factory driveline angle because many Mopar owners refuse to cut anything ...
John, I think your confusing the Tremec TKO 5 spd MANUAL withe the 4spd AOD (A41), I've done the 4spd AOD (A41) in a 71 B body with NO mods to the floor, driveline angles were within factory specs, the 4spd AOD is no larger than the TF727, the 4spd AOD (A41) was truly a "bolt-in" kit application
Thanks Mike , I don't know much about that auto trans and whenever I see something that came from Kiesler and had a NO HACK FIT I'm VERY SKEPTICAL after seeing a car with a Kiesler T5 and the bottom of the stock fan blade almost touching the radiator.
Mainstream Media is the new Pravda
