Put your multimeter between the battery negative cable and the battery negative terminal. It will show the amperage draw. Start pulling fuses until the draw goes away. That will tell you if an interior circuit is the problem.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
