Okay, I'll let you in on it. If you are familiar with these Dakota's and the wiring over by the battery then you have seen the white and black cables that run off of the positive cable. Well it was the black connector that was corroded inside the pieces that slide together. I finally got tired of having trouble and I started pulled and twisted on any wires I could get my hands on. When I moved the black cable It started running better. So I half way cleaned it and then went for a ride and no more issues. So the next day at work I had some free time so I cut the connectors out and soldered 2 copper lugs on the cables and bolted them together. Nooooo more issues. Seems I was loosing the power to the inside of the truck. And thinking about the past one day my stereo flickered. I recently broke down, the coil burned up. I think they are connected.
