Originally Posted By Finoke
I'm interested in a 70 Charger R/T that has no fender tag but 2 broadcast sheets.
The 2 sheets are identical except they have different sequential numbers and 2 different parts numbers entered at the end of row 5.
Is it normal in cars with multiple sheets to have a different sequence number on each sheet?
Does either build sheet belong to the car you want to purchase?
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
