I will be moving my springs into the frame rail and I thought about cutting the rail and using the outer portion of the rail wall and build the inside from scratch.
I left the outerside of the rail intact. You will have to use an offset rear shackle because the spring will not be centered in the rail.
This was out of a C-body and I made some spacers.
