Yep, that stuff is great! Until you want to take it apart. You basically need a stick of dynamite.
We had an old KB aluminum block that we were trying to use on the street and couldn't keep the oil and water separated. So we used The right Stuff on the sleeves. It was the only thing we tried that worked.
Master, again and still
