Originally Posted By RapidRobert
I would measure the exact front/rear clocking of the plate so you could return it to that exact position as close as you can then when done get the front wheels jacked up/off the ground and centered straight ahead/eng idling: you want the PS assist to not pull the wheels to either side
apply grease around the edges of the valve body. after replacing the O rings just put it back in the grease outline.
