AMC 360 and AMC 727 are both different than the mopar versions. If I am not mistaken the AMC 727 has a different bell housing pattern so it will not bolt up to a mopar LA block. Motor mount locations are different too, so you would need to fabricate those and possibly transmission mount too.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
