Originally Posted By DrCharles
Originally Posted By DARTH V8R
Originally Posted By Leigh
I install the lifters in the block, mark a line on them with a felt tip and turn the motor over. If one or more don't rotate, I swap positions until they all do.
Solid advice right there thumbs
So that's with no pushrods or spring pressure at all?
Turn over - at cranking speed, or just by hand with a ratchet on the damper bolt?
thanks.
Just sitting on the cam with light oil, no spring pressure. Turned with ratchet. I got the tip from Jericogtx. I'm not that smart, just ask Jeff!
