ok I finally got around to installing the headers. my original question noted that the truck was a 2WD. the 79170's hit the engine mount/cross member on drivers side. I had to cut a notch more than an inch deep in cross member. I welded a plate in to cover the hole and add a little strength. Just waned to let everyone know these headers are not an easy fit on a 2WD.
