I will give you great advice.
Call Dwayne Porter, go with his suggestion, and have him order you a cam.
He knows 100% what he is doing and that takes the guesswork out of it.
I have personal experience using his help, and the cams worked perfect.
That is great advice as its what I did. I was considering a roller but after talking to Dwayne and telling him how much I plan to drive on the street he recomended that I would most likely be happier with a solid flat tappet which I am. He speced my custom grind solid flat tappet and I could not be happier with the results and great service it has given me.
Dwayne is a Pro who does this every day and knows what he is doing and I would say he is as good as anyone out there.
Heck I have been an auto tech all my life and been around hotrods and muscle cars most of my life and feel I know cams pretty well. But I dont do it (Performance cams and heads) for a living every day and I dont run my engines on dyno's like he does when he builds them so he gets to see what has worked best and he can test his work which helps him know what works good and best. You cant go wrong calling Dwayne and talking to him. Good luck with your build which ever cam you decide on.
Ron
